It is currently Sun Aug 24, 2025 11:08 pm
Post new topic Reply to topic  [ 70 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sat May 04, 2013 8:32 pm
First name: Blake
Last Name: Dixon
City: Kelowna
Zip/Postal Code: V1V1W7
Introducing Luthier tools company's new binding cutter jig latest and greatest version starting at about 295.00 Contact Luthier Tool company to place your order. Her is a YouTube clip of the new machine. Check out the link below to the site
All the best
Blake
http://youtu.be/PPOohsQA4X0
Blake Dixon
Kelowna B.C.
PostPosted: Sat May 04, 2013 8:45 pm
Does it adjust to the height of the guitar by riding on the top?
Ken
PostPosted: Sat May 04, 2013 8:48 pm
First name: Brad
City: St. Louis
This looks like it could be the new leader in binding cutter designs!
Brad
PostPosted: Sat May 04, 2013 9:27 pm
How does one adjust height and depth of cut?
PostPosted: Sat May 04, 2013 11:00 pm
State: ON
The height of the cut is probably adjusted with the depth adjustment on the router/trimmer. I think the depth of cut is adjusted with a thumb wheel. You can see this if you stop the video at 11 seconds. Since the blank that is being cut in the video is flat I'm assuming they will have some kind of carriage setup for acoustic arched instruments, similar to other Ribbecke style binding setups.
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Sat May 04, 2013 11:57 pm
First name: Blake
Last Name: Dixon
City: Kelowna
I'm having a base sent to me directly and I will post some photos of the adjustments when I receive it. From my discussions with Chris of Luthier tool company the adjustable base can be sold separately or can be attached to any arm system or purchased complete system from LTC with everything you need minus the laminate trimmer. LTC will be updating their website with their new binding cutter systems real soon.
Blake
Blake Dixon
Kelowna B.C.
PostPosted: Sun May 05, 2013 12:07 am
Is that tearout on top or just dust from the cutter being pushed into a ledge?
If dust, I think I'm in love!
Old growth, shmold growth!
PostPosted: Sun May 05, 2013 9:51 am
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
that is also my only concern. Other than that it looks very promising.
PostPosted: Sun May 05, 2013 10:00 am
Just looks like the path of dust behind the donut to me. Not to mention he's cutting MDF.
This is a cool design, but I don't see myself becoming a convert. I see some benefits, but not enough to sell out my Williams. This design would make sneaking up on the cut pretty easy, but swapping out measured bearings seems like it might be just as quick in practice as fine tuning that final depth.
Seems like a feasible alternative to what's already out there, but not enough to make me want to sell what I already have to give it a try. Could be a good system for those tooling up depending on price. I can't wait to see the two other new system LuthierTool's been developing.
PostPosted: Sun May 05, 2013 10:27 am
This design is pretty elegant, 'engineeringly' speaking, but I don't see what advantage(s) it has over the bearing system?
Maybe I'm missing something...
Alain Moisan
(Now building just for fun!)
PostPosted: Sun May 05, 2013 10:40 am
Probably the ability to use spiral down cuts...
PostPosted: Sun May 05, 2013 11:34 am
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
Nice tool, which is what I would expect from these guys. Their designs are always high quality.
Not cheap
PostPosted: Sun May 05, 2013 11:59 am
The practical advantages over the bearing system is the ability to fine -tune the cutting size exactly to the binding, and to use a down-cut spiral bit to route the ledge which is potentially a cleaner cut, and also is less likely to rip out a chunk of wood. I make my own binding though, so if I WERE to use the bearing system, I could just make the binding perfectly to fit. In that case, the bearing system would be faster to just slap a bearing on, but in my experience, when those particular cutters start wearing out, they can rip a mean chunk of wood out pretty suddenly.
Bearings and one-inch cutter heads can be expensive to replace when parts start wearing out. Also, you have to happen to have the exact bearing for your binding, or else go under and sand the binding flush, or grab some tape and stick it to the side of the guitar. Or route the ledge a little oversize and sand the side to the binding, giving the side a slightly rounded appearance. Some people like that, so it might not be a problem.
The self-centering function eliminates the cutter disparity.
Last edited by theguitarwhisperer on Sun May 05, 2013 12:13 pm, edited 1 time in total.
PostPosted: Sun May 05, 2013 12:07 pm
Yup, it's the dust. I thought it would be odd if it WERE tearout considering the location, which is somewhere the cutter shouldn't be touching.
It looks like this could be adapted to the williams jig pretty easy, but if you've got all the bearings and have that system down pat, I'd agree with you.
PostPosted: Sun May 05, 2013 12:10 pm
If it's like my hand held tool, the height is adjusted by the router setting, the depth is adjusted by a trim knob, and the thumb wheel fine tunes the depth of the self-centering guide.
PostPosted: Mon May 06, 2013 8:53 am
First name: Nils
Last Name: Johnson
City: Boston
State: Massachusetts
I would love to cut my channels with a spiral cut bit! hmmm.
PostPosted: Mon May 06, 2013 9:15 am
I also make my own bindings, so I indeed make them according to the bearings I have. And maybe I've been lucky but after over 70 guitars, I'm still using the same bit. I have not experience much tearout, if any (climb cut is the secret). Although I should buy a new one shortly.
Alain Moisan
PostPosted: Mon May 06, 2013 9:27 am
First name: Blake
Last Name: Dixon
City: Kelowna
I was talking to Chris at Luthier tool company and he is also designing a dust collection attachment to his new binding cutter that will help in so many ways
Blake Dixon
Blake Dixon
Kelowna B.C.
PostPosted: Mon May 06, 2013 9:30 am
First name: Zeke
Last Name: McKee
I'm still unsure if this rides on the top and adjusts the depth or if it's fixed. In other words would you get an even depth on a carved top?
PostPosted: Mon May 06, 2013 9:39 am
First name: Blake
Last Name: Dixon
City: Kelowna
After talking with Chris it will ride on top of the guitar and depth will be adjusted through the router. The unit can be attached to any arm arrangement that you have previously used. I will be attaching mine to one I purchased from John at Blues Creek. I will take some photos once I have it setup
Blake Dixon
Blake Dixon
Kelowna B.C.
PostPosted: Mon May 06, 2013 10:29 am
Wow! What bit do you use? Pro sharpen? How often?
PostPosted: Mon May 06, 2013 11:15 am
First name: Blake
Last Name: Dixon
City: Kelowna
Chris recommends a 1/4 in downward spiral cutting bit. The beauty of this system is you use one bit to do all your Channel cutting. Attach this cutting base to any arm or upright stabilized system and away you go
Blake Dixon
Blake Dixon
Kelowna B.C.
PostPosted: Mon May 06, 2013 11:55 am
When I was talking to him, he told me the mechanism that allows it to follow the top would be gas balance to minimize the pressing on the top due to gravity.
Is this still a feature?
When will this be up on his website for me to order?!? bliss
PostPosted: Mon May 06, 2013 12:04 pm
First name: Blake
Last Name: Dixon
City: Kelowna
Pretty sure the gas shock system is still a feature that will be available. This should be up on his website this month
Blake Dixon
Blake Dixon
Kelowna B.C.
PostPosted: Mon May 06, 2013 12:26 pm
It's up on the page, now, hit F5 to refresh your web page.......
Gas shock system is not a feature, spiral bit needs the weight.
Not a problem though....
He also has a horizontal version system coming out that will also be super slick, and another hand held....
Three new binding systems.
LOVE this company!
Users browsing this forum: dofthesea, phavriluk and 20 guests
